Glow Gauges
you could probably ground the guages to any free bolt and is the guages gonna be on a dimmer switch or not cuz that will change how you hook it up. If it is then you splice it into the dimmer wire, if not then you can probably just get the power from a fuse if you want to, thats the easiest cheap way to do it.
