Glow Gauges
Old Sep 4, 2006 | 05:42 AM
DrumMaster's Avatar
Default Glow Gauges
Hey,
I need to know what wire to connect to inorder to power my new glow gauges.
Which wire and where is it?
Also, where is the best place to ground the gauges?
Thanks!!!
Old Sep 4, 2006 | 12:10 PM
Default RE: Glow Gauges
you could probably ground the guages to any free bolt and is the guages gonna be on a dimmer switch or not cuz that will change how you hook it up. If it is then you splice it into the dimmer wire, if not then you can probably just get the power from a fuse if you want to, thats the easiest cheap way to do it.
Old Sep 4, 2006 | 01:44 PM
oh_what_up's Avatar
you can always tap them into your tail light wire. It runs along side the driver seat underneath the door sill. If you cut into the wire loom it is the green wire.
pilsenblue
Feb 3, 2008 08:51 AM
kryptekz
Sep 1, 2007 09:11 AM
Kahuna
Mar 6, 2006 09:32 AM
Atownprepy99
Jan 5, 2006 03:23 AM
taylor61387
Mar 26, 2004 12:30 AM
