helpful info on Installing new white glow gauges
Old Jan 8, 2008 | 01:43 PM
pilsenblue's Avatar
Default helpful info on Installing new white glow gauges
So i am installing new white/blue at nightglow gauges. Anybody do this and how hard is it gonna be? Any tricks to get this dash off. any help fulinfo would be great. Its cold in chicago and I dont want to be stuck outside all day with this.
I have a 97 rs
Any advise on wiring this up would be great
Old Jan 8, 2008 | 02:05 PM
Default RE: helpful info on Installing new white glow gauges
it shouldnt be to difficult. To remove the dash just start taking off screws. Once you have them all off the dash will just snap off. Then the guages will just go right over the stock ones. You just need to find a place to tap into for power.
Old Jan 8, 2008 | 02:39 PM
pilsenblue's Avatar
Will the needles just come off ? (speedo,Rpm's) so I can slide it in?
Old Jan 8, 2008 | 04:30 PM
yea you just have to remmeber the postion they were in and make sure that they are correct after your done
Old Jan 25, 2008 | 02:27 PM
pilsenblue's Avatar
Default RE: helpful info on Installing new white glow gauges, how to power them?
Where and how should i run power to the gauges. It cold outside in chicago and I dont want to be out side all day. any help . Electical work kinda scares me something. Not sure what im doing. any help as basic has it might seem to you will be helpful thanks
Old Jan 25, 2008 | 02:37 PM
pilsenblue's Avatar
Default Glow gauges , Wiring , Power, How too
Old Jan 25, 2008 | 07:37 PM
RCJr9186's Avatar
Default RE: Glow gauges , Wiring , Power, How too
when i had mine on my 99 gs i tapped into the cig lighter light... worked jsut fine. when you get them on, place them back in/on the car and plug it in and all. turn the key to on (just before you crank it) right then your speedo and tach should be set to 0. so place the needles on right then on 0 and they will be set correct.
Old Feb 3, 2008 | 08:51 AM
endlesskustumz's Avatar
i put them in my 97 gst... after you get the gauge cluster out you can put the face on inside that way you dont have to be outside for so long.. i am from NW Indiana bout 30 mins from chicago.. so i know what you mean about the weather especially the lake effect.. anyways it isnt that hard to put in.. make sure you hook everything up correctly and take your time otherwise you could mess some stuff up...
kryptekz
Sep 1, 2007 09:11 AM
DrumMaster
Sep 4, 2006 01:44 PM
Kahuna
Mar 6, 2006 09:32 AM
Atownprepy99
Jan 5, 2006 03:23 AM
EclipseSlimRS
May 16, 2004 07:10 PM
