Is this a good deal?? FAST
Old Feb 6, 2007 | 04:45 AM
keithscianna's Avatar
Default questions for turbo conversion
I know i need to get a new clutch, But do you think i could run 6lbs and be ok with my stock clutch? If not what would be the max boost to push on a stock N/T clutch.
Also what clutch should i get? I know the turbo clutch wont fit into the N/T Tranny. Also if i get a turbo header will it bolt up to the exhaust already on my car?
Old Feb 6, 2007 | 09:36 AM
Default RE: questions for turbo conversion
Your gonna need to get a downpipe. And for a clutch the stock one should be fine, unless its already worn.
Old Feb 6, 2007 | 10:44 AM
RCJr9186's Avatar
not TO familiar with the n/a 4g63 but if the stock internals and clutch in the 420a are good up to 10lbs... i'd say you are probably safe running the same boost on your motor. when you do upgrade your clutch, it all depends on what kind of use you have in mind for the car and also depends on how much power you are looking for.
Old Feb 6, 2007 | 11:52 AM
1st gen manifoldO2 Sensor(small crack, can be easily welded)WIll that work or should i get a new one?
thanks
Old Feb 6, 2007 | 11:53 AM
RCJr9186's Avatar
a weld will do just fine but personally. . . i'd get a new one
santi210
Sep 21, 2007 07:36 AM
paintballproam
May 12, 2006 06:57 PM
JonathanSQ
Apr 4, 2006 12:46 AM
5Tizzle
Feb 7, 2006 05:09 PM
lunareclipse
Dec 28, 2005 08:47 PM
