recommendations
Old Feb 6, 2007 | 03:51 PM
98eclpsrider's Avatar
Default recommendations
alright, when i get on the gas on my 98 eclipse GST it seems like it boggs down then comes back up, like it's gasping for air. and i was wondering if it has to do with the fuel injectors and pump. I have stock for both and running and adverage of 13psi, and my mods are in my sig. I was just seeing what you guys think on recommendations on fuel injector size and fuel pump, i'm wanting to get at the end of modding to get consistantly above 300hp.
Old Feb 6, 2007 | 03:54 PM
RCJr9186's Avatar
Default RE: recommendations
well if you are still running stock turbo i wouldn't say that's fuel cut but if you are planning on runnin above 300whp though i'd suggest upgrading it anyways a walbro 190 will do you plenty to get up to that number, as for injectors... 550's should be plenty i'd say along with a rrfpr. get a simple safcII and a street tune on a big16g and you should be there no problem.
Old Feb 6, 2007 | 03:58 PM
i believe it's a stocker turbo, but i plan on getting a evo III big 16 G turbo and intercooler to cool the air.
Old Feb 6, 2007 | 04:03 PM
Well if its not bogging really hard like your hitting a wall then it may not be fuel cut.You might have a boost leak
Old Feb 6, 2007 | 04:12 PM
jerusry's Avatar
look up in search button BOOST LEAK check... that will be your culprit 99% of the time is what i have learned. and there is a ton of stuff on it!! good luck with it.
Old Feb 6, 2007 | 04:13 PM
it boggs noticable, sorta like it goes to motor then to turbo power then to motor, it only happens when it gets to the highier RPM's around 6k and beyond when i get on it. if i go up slow through the rev it dosen't happen.
Old Feb 6, 2007 | 08:23 PM
Simss's Avatar
ORIGINAL: RCJr9186
so just out of curiousity what is a "rrfpr"?
Old Feb 6, 2007 | 08:35 PM
pats90gsx's Avatar
ORIGINAL: Simss
He keeps referring to it as a rising rate fuel pressure regulator. If he says that just replace it with AFPR.
Sanguinius
Other Mitsubishi Models
Jan 3, 2007 08:33 PM
DryBear
Mar 24, 2006 10:34 PM
twinstealthytalon
Oct 22, 2005 06:34 AM
FireDoc
Oct 14, 2005 01:05 AM
bigjohn
Sep 27, 2004 04:48 PM
