hard Break pedal
Old Jul 1, 2008 | 09:49 PM
98gstspy's Avatar
Default hard Break pedal
ok so today i moved my car into the garage so i could work on it. ongoing project for a while. the car has been sitting scence feb. and when i pulled it out i noticed that the break pettle was hard to push down. it wasnt like this when i drove it last or atleast i dont remember it being this bad. there is surface rust on the pads that went away some but the pettle only lossened up a little. fluid is full so idk what the problem could be. any ideas, one person who i talked to for a min said air could possibly be in the lines???
Old Jul 1, 2008 | 10:00 PM
tjbiker031's Avatar
Default RE: hard Break pettle
was the car running when you moved it? it if was maybe the master booster or pistons on the brakes were just stiff from not moving.....wouldnt hurt to bleed out the system too.
and its not "break pettle" its BRAKE PEDAL!!
Old Jul 2, 2008 | 12:49 AM
sk8dudety's Avatar
yea man if the car wasnt running then the master cylinder wont release, or maybe it's too full if it was running? idk, thats a strange one
Old Jul 2, 2008 | 08:37 AM
98gstspy's Avatar
ok so yea sorry bout the spelling thing so i should just bleed the system and see what happens. and yes every thing was fine except for the iac before i stopped driving it. breaks and all.
Old Jul 2, 2008 | 12:00 PM
dsm1990gsx's Avatar
Ok if the car want running that is normal b/c your not getting vacuum to the booster which aids in brake assist. If it was running and you had a hard pedal I would inspect the vacuum line to the booster.
Old Jul 2, 2008 | 12:10 PM
Could be crap in the lines.
Try flushing the old fluid and replacing it with new.
cllamont
4th Generation
11
Oct 6, 2014 02:21 PM
nktaylor
Feb 27, 2006 03:55 PM
slash_guy
Jan 18, 2006 10:51 PM
Angel_408
Mar 1, 2005 05:20 PM
jfvalejandrino
Jun 8, 2004 06:07 PM
