Head Gasket Leak...? on repairs
Old Mar 15, 2005 | 01:08 AM
TheMongoose's Avatar
Default Head Gasket Leak...? on repairs
Ok, so I have this infamous head gasket leak on my Eclipse with the Dodge 2.0 NT motor. For any of you that have repaired this did you have to do the water pump at the same time? Does it make sense to do it while you're in there? I am planning to do the timing belt. Thought that a new one might wear out the water pump bearing if I didn't cange it out. What do you guys think?
Old Mar 15, 2005 | 04:54 AM
1398spdr's Avatar
Default RE: Head Gasket Leak...? on repairs
if your gonna do the timing belt, do the water pump too, itll save you time doin it later, and possibly your head, not to mention the new head gasket you just installed.............
Old Apr 12, 2005 | 10:18 AM
modestmitsu's Avatar
If your going to replace your hed gasket change your timing belt and gears with it, youll save yourself a whole hell of alot of money, do everything at once, water pump would be a wise decision aswell!
Old Apr 13, 2005 | 01:26 AM
Sanguinius's Avatar
If you've got the time and $ then go for it. IT'll save ALOT of time in pulling it off again later and replacing it. Besides it may be playing partial culprit to the whole head gasket problem in the first place. Why not take care of it now before it goes bad completely? (I've seen a water pump bearing go and watched as the pump straaight SHREDDED the teeth of the belt).
Davecancu
Jan 7, 2009 12:43 AM
Davecancu
Dec 25, 2008 02:45 AM
Sanguinius
Nov 14, 2006 08:05 PM
tammy ated
Mar 14, 2006 03:54 AM
chrisg
Mar 29, 2005 06:42 PM
