help 2g eclipse or 3rd
Old Apr 22, 2006 | 07:54 AM
Default RE: help 2g eclipse or 3rd
gts IS A v6 and gas milae is much better that a mustang or a turbo eclipse
Old Apr 22, 2006 | 11:53 AM
ictponder's Avatar
All 3g's with leather are gts? Or just the Spyder?
I've also talked with someone at Tearstone and they said the 3G can handle more than 8psi as long as you get the engine tuned.
Old Apr 22, 2006 | 12:47 PM
ORIGINAL: ictponder
ya the 4 cyl 4G64 can but the GT can only take 8 psi tuned and the GTS only 6psi. No matter what the engine MUST be tuned to run any boost on these car, but the 4 cyl GS\RS takes to it much better than the V6
all V6 from 2000-2002 are only GT no matter the package rated at 205hp
from 2003-2005 the GT is still V6 rated 205Hp
the GTS is v6 rated at 215hp and all GTS were loaded.
2003-2005 gt COULD GET THE LEATHER AND cd CHANGER AS WELL BUT IT COSTS EXTRA THE gts CAME WITH IT ALL. AND ALL 2003-2005 V6 spyders had the GTS motor rated at 215
Old Apr 22, 2006 | 03:57 PM
dreamz's Avatar
thnx for the info i think i am going to base it on what ever is best price at the time, also is v6 get better mpg than 2g turbos ?
Old Apr 22, 2006 | 06:52 PM
V6 is rated at 21-23 I think and the 2G turbo is the same if im not mistaken maybe one or two more
Old Apr 23, 2006 | 09:54 PM
dreamz's Avatar
stock wich would be faster there both pretty heavy vechile and about same horse power ?
Old Apr 23, 2006 | 11:16 PM
i think the gst is alittle quicker from stock but with very small mods the gst will be alot faster.
Old Apr 23, 2006 | 11:18 PM
ORIGINAL: dreamz
GTS>GT fed spec>GSX>GS-t
^ the GTS is slightly more HP. the Fed spec was only 2000s and some 2001s they are just less restrictive than Cali spec 3Gs. I was basing off of 1\4 mile but remember these are all almost .2 apart
for example ive seen
2003-2005 GTS run 14.9sish
2000-2001 GT fed 14.9sish
2000-2005GT cali 15.2ish
1995-1999 GSX 14.9ish
1995-1999 GS-t 15.0ish
that is all on the coupe the spyders are slower than that and the cali spec spyder is like 15.7s
nbgsultan
Mar 19, 2013 06:41 PM
rafael_o0o0
Sep 23, 2011 04:10 PM
captawesome385
Jan 25, 2009 04:21 PM
duwacker16
Jul 5, 2008 02:47 PM
DriftnROCKER77
Jan 16, 2008 01:20 AM
