HELP! 97 a/t 420 n/a
Old Apr 13, 2006 | 05:35 PM
fwerp's Avatar
Default HELP! 97 a/t 420 n/a
Im having trouble finding info on how to wire up my fuel air meter..... the car is a 97 eclipse GS 2.0 n/a with the 420a. all i need to do is find out which of the two oxygen meters to tap into and where/what line
Old Apr 13, 2006 | 11:51 PM
slow420a's Avatar
Default RE: HELP! 97 a/t 420 n/a
I so did that and it was a paint in my butt. The advice that I can give you now is that you want to tap the reading wires not the ground/hots. The black is a ground, the gray is a hot, and their are two white ones. I did a trial and error thing and it worked but the two white ones are the fellas to get.
Old Apr 13, 2006 | 11:58 PM
fwerp's Avatar
http://www.machv.com/machv/95turec.html <-- this is turbo model.... does this sound right? 0r should i just go for it on one of the whites from either oxy sensor?
RCJr9186
Jan 24, 2017 02:05 PM
jethro
May 30, 2007 02:18 AM
Darkspeed
Oct 4, 2006 09:15 PM
Darkspeed
Aug 29, 2006 09:41 AM
green_gs12
Aug 4, 2005 05:34 PM
