Help Guys, I loss power, car won't run
Old Oct 19, 2007 | 08:11 PM
driftin2u's Avatar
Default Help Guys, I loss power, car won't run
The engine light kept coming on. So I changed the head gasket and plug wires then drove it 3 miles down the road . It was runing fine a little skip then it was like a thump andit started losing power, it was cutting out really bad. I drove it back home and got new bosch plugs and put them in and the engine light is staying on and it is still skiping couldn'tget the ngk plugs they are on order. don't know what is wrong with it. checked with a meter and it said it was misfiring on all plugs. I have a 97 eclipse with turbo GTS. Help guys I don't know what to do.
Thanks T [sm=bounceybounce.gif][sm=bounceybounce.gif]
Old Oct 19, 2007 | 09:25 PM
TheAdvocate's Avatar
Default RE: Help Guys, I loss power, car won't run
Make sure to check your timing.. If your belt skipped a tooth you could ruin some valves if you keep running it.. But trace your wires back and double check you have them all on the right plugs.. That will make it run like crap, if it even starts..
Old Oct 19, 2007 | 11:31 PM
chopper1's Avatar
Coil???
Old Oct 21, 2007 | 05:20 PM
tjbiker031's Avatar
90% sure timming
Old Oct 22, 2007 | 06:53 AM
Im gonna go with the timing belt also. You may have just trashed your head. Who did the head gasket?
Old Oct 22, 2007 | 07:29 AM
ORIGINAL: chopper1
Coil???
my thoughts as well... maybe he plugged them in wrong cause that is easy to do.
Old Oct 22, 2007 | 10:56 AM
atown420's Avatar
could it be the alternator? i had similar problems with losing power and it was the alternator and the wires that plug into it had bad connections.
Old Oct 22, 2007 | 05:22 PM
nick_200321's Avatar
misfiring on all plugs, sounds like timing to me also.. but really bosche plugs arent good in these cars either, they can make you bog down. i would check timing then if it is not correct i would then check the coil.. but i hope you didnt trash the head..
jdohe
Dec 12, 2010 07:00 AM
Shadowplane676
Dec 23, 2005 08:37 PM
BCS
Dec 7, 2005 04:26 PM
Buckeyejack
Feb 24, 2005 07:28 AM
Newbiedude
Jun 22, 2004 02:50 PM
