HELP!!! please, car died and won't run anymore
Old Dec 16, 2005 | 01:27 PM
Shadowplane676's Avatar
Default HELP!!! please, car died and won't run anymore
ok, the car has been stumbling for a while, and just the other day, i let it warm up in the morning and it stalled out, and hasn't started since. [:@]it will crank over all day long, but there is no spark, and no fuel that i can smell (i.e. flooding or non-combustion) i have replaced teh fuel filter, coil, plugs, wires, cap, rotor, ASD (auto shutdwn relay) and tried a diff ECU and still nothing. i am at wits end as to what is wrong with this car. please, any advice would be most appreciated, thank you
Old Dec 16, 2005 | 02:59 PM
nightseer's Avatar
Default RE: HELP!!! please, car died and won't run anymore
what about the fuel pump?
Old Dec 16, 2005 | 09:30 PM
As far as i know the fuel pump is still fine, no whine or any telltale signs that it is a fuel issue
Old Dec 20, 2005 | 06:19 PM
jakster's Avatar
Sounds like the computer,bummer is you may have waited to long if the engine was studdering for a while thats the first sign the capasitors are leaking on the board. The second sign is the acid in the capasitors have shorted the main board out and its toste. The third thing is the $400 you will pay for the rebuilt unit because your old one is beyond repair and you have no core. Sorry to screw up your Holliday with thaat news. Still send the old one as a core maybe they can fix it.
Old Dec 20, 2005 | 10:35 PM
well, got it fixed brought it to a mechanic (thank god for AAA :-p) turns out it was the distributor, the hall effect trigger for the coil had died. at least im back up and running, thanks for all your help people :-D
Old Dec 21, 2005 | 08:57 PM
jakster's Avatar
What is the Hall Effect Trigger ???????????
Old Dec 22, 2005 | 03:49 AM
its part of the distributor responsible for telling the coil to fire when the rotor is in the correct position for firing a spark plug. a little more about a hall effect trigger can be found at the following site
http://www.picotech.com/auto/tutoria...r-signals.html
Old Dec 23, 2005 | 07:38 PM
jakster's Avatar
Ok now I have a better idea what the hell a hall is. How much did it cost I know the garage slamed you but break it down for us and maybe some more on how the car was running would help someone figure out a problem. Loke was it a studdering as you accelerated or loss of power or what. Thanks we need to develope a data base on trouble shooting tips this would help.
Old Dec 23, 2005 | 08:37 PM
ok, it started out as a stuttering/stalling occasionally, it would stall at ilde at a light or something but it seemed like it was misfiring, or running on less cylinders. it got progressively worse with odd occasions where it would run fine for a bit, until it stalled one last time. after that, it wouldn't start at all (i.e. no spark). the shop luckly put in a used distributor ($80 us) and wacked me 1 hours labor for $65. i would have never guessed it was the distributor so hopefully this ends up helping someone.
pj4411
Jun 10, 2010 04:48 PM
hubert hefner
Mar 20, 2010 01:46 AM
corsair_105
13
Feb 25, 2010 09:06 PM
driftin2u
Oct 22, 2007 05:22 PM
stlrobb78
Dec 2, 2004 12:05 PM
