High Temp at Idle
Old Feb 17, 2004 | 06:22 PM
shmadiohead's Avatar
Default High Temp at Idle
<FONT face="Arial, Helvetica, sans-serif" color=black size=3>Low temp at normal speeds - High Temp at Idle.</FONT></P>
<FONT face=Arial size=3>Coolant, hoses, and Thermostat have all been changed yet problem persists. How do I diagnose further?</FONT></P>
Old Feb 17, 2004 | 06:24 PM
<FONT size=3>By "Low Temp", I mean "Normal"</FONT></P>
Old Feb 20, 2004 | 02:26 AM
ListenersAudio's Avatar
I was having that same problem with my truck. It was my thermostat. I dont know much about imports but Im guessing it should have the same thing. sorryif im not much help but its just a guess.
Old Feb 23, 2004 | 05:22 PM
oldmansgs's Avatar
<IMG src=smileys/smiley19.gif border="0">Dude, check to see if your cooling fan for radiator is coming on at idle when fully warmed up.I have to believe that either your fan motor is not working or switch that tells it to come on is bad. The reason you don't overheat at normal cruising is air flow into radiator while you're moving is usually sufficient to keep things cool. Hope this helps, Randy
Profbx
May 17, 2013 02:09 AM
fiveightandten
May 31, 2010 07:54 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
dnau
Apr 24, 2005 05:12 PM
1rippinGT
Apr 7, 2004 06:09 PM
