Hood scoop
i would say a little, it also depends on the air on the outside too. if it's hot then it won't, during the cooler season then it will help some. synthic oil believe it or not, will cool down your engine some, because of less friction. but other than that and some sort or cold air intake...that will cool it down some, but since there's not room. Other than that, it's all i got.
header heat wrap, turbo heat wrap, intake insulation... these will all keep it cooler under there. i've read in some places that header and turbo wrap can reduce the heat under the hood by like 65%... not sure how true that is but it's a cheap way to stay a lot cooler.
ORIGINAL: RCJr9186
ORIGINAL: dirtwagon
An EVO style hood should keep you quite a bit cooler in the engine bay...the ambient temp. outside will never match the temp in the engine bay of your car.
ORIGINAL: RCJr9186
