How much can I boost my car up
Old May 3, 2006 | 06:51 PM
anko_kun's Avatar
Default RE: How much can I boost my car up
16 psi is the safest hi psi you want to run on a stock fule system
Old May 5, 2006 | 12:54 AM
B.e.R.a.T's Avatar
ok i know i can boost up my car all the way to 16 psi. is it gonna be the peak or continious psi of my car???
Old May 8, 2006 | 01:15 AM
n2daizo123's Avatar
16 should be your peak. as the rpms go up the boost should start going down to about 10-12 at about 5800.
Old May 8, 2006 | 11:04 AM
a 4 psi drop is way to much. If you set the peak up to 16psi then the most i think it should drop is around 2 psi to around 14.
Old May 8, 2006 | 02:41 PM
n2daizo123's Avatar
when i dynoed my car it hit 14 and at redline it was at 10. maybee something is wrong with mine?
Old May 10, 2006 | 09:42 AM
B.e.R.a.T's Avatar
I just got done installing the BOV and MBC. my car peaks @16 psi then drops down to 13psi if I adjust my BOV (Greddy RS) it will hold the pressure but I am afraid that it might damage the engine or the turbo so I am happy with it. I installed my BOV with recirculation kit and I was wondering if it will do any damage on my car if I didn't recirculate and just blow it out to atmosphere. any opinion. thanks
Old May 10, 2006 | 02:46 PM
talon4show's Avatar
Well 15 should be the max on that turbo for you. The turbo itself can handle quite the load its your fuel system that can't. If you are running like 15psi you are going too far. I see you are spiking at 16 and steady at 13...that is good. Just don't let it go past 16.
agallardo
Dec 7, 2006 09:43 AM
gstTurbo2011
Sep 8, 2006 12:00 AM
thehintons06
Jul 25, 2006 10:31 AM
thehintons06
Jul 12, 2006 07:08 PM
turbobird14
Aug 8, 2005 10:37 PM
