i think i may be a victim of crankwalk
Old Feb 28, 2007 | 01:37 AM
Default RE: i think i may be a victim of crankwalk
I have no idea. That is something that changes a lot from shop to shop.
Believe it or not, changing the motor for an exact replacement will be easier and less labour
Old Feb 28, 2007 | 01:46 AM
natewesselink's Avatar
thanks i sent joshewa (ya i spelt it wrong too) a pm and im waitin for a reply
will it cost more than 600 to buy the engine and put it in(just a general number would be ok)
Old Feb 28, 2007 | 01:50 AM
No. he was saying he was going to be able to pick up the wrecked car for next to nothing. So i dont think he will rip you off... i defenatly dont think he will ask anything near 600. The rest will be labour
Old Feb 28, 2007 | 02:08 AM
how mutch would the engine be i have a budget of 600 bucks for engine and labor how many hours would a swap take
Old Feb 28, 2007 | 09:35 AM
I have an engine i really want to get rid of. But it would be a matter of whether you want to do the 6-bolt swap.
Old Feb 28, 2007 | 10:05 AM
RCJr9186's Avatar
i was just about to say that TheEngineer has a 6 bolt for sale. you mentioned that you were looking to make your car as fast as possible... well he has the motor you want if you want power.
Old Feb 28, 2007 | 10:48 AM
Thats not cost effective though. Although more reliable, doing the 6 bolt swap is costly. Not something he has the time or cash for.
Well for 600 bucks you are kind of limited. Hopefully Josh will give you that motor for a decent price. After that, you need to call around at shops asking for a flat rate to swap the motors. Making sure you tell them that they are exactly the same motor and will drop right in.
Old Feb 28, 2007 | 12:41 PM
well these are the parts involved in the swap
Parts List
1G CAS (91-92 Optical Effect, 93-94 Hall Effect)
1G Oil Cooler (90-92 MD 157670 6bolt water cooled oil cooler)
1G Water Pump
1G Oil Pump/Front Case
1G Timing Belt necessities
2G Engine mount (modified) use 2G engine mount trimmed, with 1G tensioner arm
1G Timing Belt Covers (modified)
1G 90-92 6-bolt block (with whatever internals)
1G 6-bolt Flywheel
2G Starter Mounting bracket
1G Water Pipe
1G lower radiator hose
1G Thermostat housing/ Water Neck
1G 6-bolt oil pan Balance shafts (remove them or keep em, its up to you, we take them out)
2G Alternator
2G Power Steering Pump
2G A/C 2G Belts
But like sebba said this isnt something that would be done for $600. And even dropping in a new 7-bolt block i dont know if that would be possible either with that money. Most places will charge around 1-2k to do it, with parts. I guess if you got the parts cheap it might be close. But it really depends on the shop. Also remember you get what you pay for. Emonz had a new engine dropped in his 3g GS and the took forever and did a terrible job. The pinched AC lines and the clean up was crap.
Old Feb 28, 2007 | 07:53 PM
i talked to jhosheewa and he said he passed on buyin the wrecked gsx plus it bein a gsx he swapwouldnt be direct i would need a new ecu and wiring harness and alot more so im gana pass on that and just get mine fixed thanks alot for the info guys and this is just an afterthought but how mutch(on average) would a6 bolt engine cost me because in the future im lookin to add up to 300 horse to my car i want it to get good gas mileage but i also need it to be a daily driver untill i get out of collage and be makin more than 20000 a year (im only makin round 5000 now) thanks for the info and any help on what i should do to my car to make it as fast as possable but still be economic enough to be my daily driver
Old Feb 28, 2007 | 08:48 PM
<<<<$100
A more usual price $200
_it___is_i
Apr 26, 2014 01:55 PM
Black9On7Black
Mar 7, 2007 01:49 AM
TheEngineer
Jan 26, 2006 09:58 AM
congonator
Dec 21, 2005 11:26 PM
petro4411
Nov 29, 2005 06:06 AM
