ignition
Old Apr 24, 2007 | 09:18 AM
Default RE: ignition
me too,cuz timing being off is a much worse situation than just an air leak or a bad IAC motor
Old Apr 24, 2007 | 09:42 AM
darknigh7th's Avatar
talking about air sensors, my air pressure sensor on my intake manifold is messed up, anyone have one i can get or a cheaper one than freaking autozone. they want 130, but if thats a usual price... then damn.
Old Apr 24, 2007 | 09:44 AM
Thats a usual price. Im assuming your talking about the MAP sensor. What makes you say that its bad?
Old Apr 24, 2007 | 11:27 AM
RCJr9186's Avatar
he's just throwing something out there as an option but i doubt that's it. this could be a TON of things. boost leak, bad/old sensor, timing belt, aic, tb leak, plugs, wires, distributor... just start with the easiest. boost leak (you can make a boost leak tester w/ some pvc pipe, 90 bend, coupler and compressor), chang ur plugs, check timing w/ timing light... these are all very simple and cheap checks.
Old Apr 24, 2007 | 12:11 PM
my cel send me a malfunction in that sensor, i called my mechanic he says it's probably bad, so i'm gonna test it and if it's bad... well then i have to drop 130. It's also making my idle bounce a tad bit, I've done the leak test, all that jazz, it's the last thing i could figure.
Old Apr 24, 2007 | 12:17 PM
RCJr9186's Avatar
well there you go. have fun under your car w/ the sensors lol
jrmdir
15
Oct 17, 2020 12:13 AM
allallyouyou
Feb 12, 2012 11:13 PM
visionstudios
Sep 29, 2005 02:02 AM
curtisj85
Apr 22, 2005 07:43 PM
get435
Jan 3, 2005 01:18 AM
