Ignition Systems
Old Jan 2, 2005 | 11:45 AM
get435's Avatar
Default Ignition Systems
I have been looking around and i want to get an ignition system i look at msd because i noticed that alot of high HP and drag cars use there ignition system. dose anyone have any experiance with ignition systems if so do u know some suggestions i am currently looking at msd Stacker Ignition, 4-Channel Distributorless. and i got a msd coil pack car dose seam to run a little better already from the coil pack and it was about twice as heay as the original dont know if that matters i do know that msd has the ignition that fires many times insted of onlu once so more fule is burned. any suggstions or has anyone used these products?
Old Jan 2, 2005 | 10:25 PM
vertstanggt's Avatar
Default RE: Ignition Systems
MSD is one of the best ignition brands you can go with, you pretty much can't go wrong with their stuff. What do you have done performance wise? If you havn't done much don't spend the money on an ignition right now, wait till you have everything else most of the way to where you want it then worry about that.
Old Jan 3, 2005 | 01:18 AM
midnght's Avatar
If it is any condolence the stock ignition is fine even up to 515whp. I have seen it more than once.
allallyouyou
Feb 12, 2012 11:13 PM
sk8dudety
Dec 26, 2007 11:17 PM
customizedrides
Jan 25, 2005 01:21 PM
nate5023
Jan 2, 2005 11:32 PM
get435
Nov 26, 2004 08:31 PM
