INjector Good or bad?
hey how do i find out if my injectors are working right because my car is running really lean and i know it is getting proper fuel pressure to the fuel rail and it is getting spark. also i when i took the spark plugs out it had smoke flowing out of it. and smoke smelled like a weird burned smell.
thank you
brandon
thank you
brandon
it does run horriable it doesent even start. it just cranks over and back fires alot while cranking and then the car will start but only stay at about 300-500rpms and it will buck and back fire like crazy.
ORIGINAL: thehintons06
and the burning smelll smells more like metal burning then oil burning.
I would check the ohms on all the injectors by pulling the clip out of it and touching to the two pins on the harness.
