My 420a still won't start?
Old Oct 14, 2007 | 08:44 AM
95eclipse420a's Avatar
Default My 420a still won't start?
It cranks & then it will backfire out of the intake, but thats all i can get out of the car,
last time i posted on here everyone told me it was the timing, My new question is what should the cams be set at? they are crower stage 3 cams, with unorthadox adjustable cam gears, everyting lines up like it suppose to timing wise, so now im thinking maybe the cams are off? I have the abilitly to advance them 10 degrees or retard the 10 degrees? can any one recomend what they should be set at?
Old Oct 14, 2007 | 11:43 AM
Default RE: My 420a still won't start?
All the timing marks should be lined up. If all of them are lined up, then i cant imagine what is going wrong.
Old Oct 14, 2007 | 01:18 PM
nick_200321's Avatar
try to retard the cams a little bit, it sounds like it is mixing too much gas in and stalling out.
Old Oct 14, 2007 | 11:06 PM
The only reason for backfiring through the intake is timing...
Old Oct 14, 2007 | 11:18 PM
right, and if you retard the cams slightly, wont that help with the timing?
Old Oct 19, 2007 | 08:00 PM
chopper1's Avatar
Is it possible that the crank/cams are 180 degrees off.
mysticrythms
Mar 19, 2014 08:17 PM
frank101
Jan 23, 2012 06:07 PM
JuggaloD
Nov 25, 2008 04:24 PM
buzzkill01
Nov 16, 2006 01:36 PM
Shownolove
Apr 26, 2006 10:54 PM
