Still Won't Start
Old Apr 2, 2006 | 09:49 PM
Shownolove's Avatar
Default Still Won't Start
My 98 Eclipse still wont start . I checked the cam sensor and its good , but the coil pack sensor i cant get a read on my analog reader . It has gas , fuel pump works . I took a spark plug out and tryed starting it and still i didnt smell any gas . But not getting gas doesnt have to do with spark . Ive tryed everything . Does anyone have some good insight on if it could be the ecu, or computer , or theres just something not plugged right??? there is no current getting to the coil pack plug! Help! ive tryed everything , so if you post give me insight on what the many things it could be instead of telling me to check this and that , cuz i checked everything , or i overlooked something!
Old Apr 7, 2006 | 08:41 PM
NESpeed's Avatar
Default RE: Still Won't Start
Well if you are not smelling gas....then its could be a few things, try taking some starter fluid and see if it kicks over from that. If it does then you need to check your fuel system. Did you check line pressure?
Old Apr 8, 2006 | 08:14 AM
magnet's Avatar
I would do what NESPEED said first off, and if that doesnt get it I would definatly jump power to the coil pack plug-in and see if it fires then.
Old Apr 8, 2006 | 08:20 PM
Shownolove's Avatar
I havent checked any of the lines but the fuel pump does kick on , but its just not getting spark at all , idk what to do !
Old Apr 8, 2006 | 09:40 PM
magnet's Avatar
ok...how did what I suggested work out?
Old Apr 9, 2006 | 05:17 PM
Shownolove's Avatar
There is fuel in the lines ! but no spark still , i tryed jumping the plug on the coil pack and that didnt work either!
Old Apr 9, 2006 | 08:02 PM
Sanguinius's Avatar
All right FIRST OFF chill out dude. You're not giving us ANY info to go on. Merely telling us there is fuel in the lines and there is no power in the coil tells me absolutely NOTHING. First off Are you checking for spark at the end of the plug wires? If so how are you testing for spark? And have you tried REPLACING the plug wires? As for the fuel... Have you put a fuel pressure tester on the fuel rail? Then how do you know there is fuel in the lines? Just because the pump is running doesn't mean it's actually sucking fuel. Maybe your tank is empty and the gas guage is off. Maybe the in tank filter is clogged and you're not getting gas to the engine. Maybe you in LINE filter is clogged and yout pump isn't getting gas past it. PLEASE don't tell US you've checked EVERYTHING as if you HAD checked EVERYTHING you'd have found the problem now wouldn't you. We will do our best to help you but if you're not willing to help yourself then there will be nothing we can do to help you. Any of the symptoms you describe can be caused by multiple problems and certain tests are required to narrow down the possibilities. If you can't or are unwilling to do the tests then we can give you a 50 page list of all known problems and let you throw parts at the car all day. Sorry if I sound like a ***** but you can't tell us "I get no spark from the coil" and expect us to tell you EXACTLY what your problem is.
Old Apr 26, 2006 | 10:54 PM
xslim69's Avatar
hey guys i have a symiler problem as the other guy but i tesetd every thing from the camshaft senser to the coil packs, im getting spark but the no fire. i also replaced the ecu and that didnot solv the problem. do u guys have any segations. thanks
mysticrythms
Mar 19, 2014 08:17 PM
frank101
Jan 23, 2012 06:07 PM
95eclipse420a
Oct 19, 2007 08:00 PM
buzzkill01
Nov 16, 2006 01:36 PM
flipp117
Oct 26, 2006 03:07 PM
