INjector Good or bad?
Old Oct 17, 2007 | 08:37 PM
thehintons06's Avatar
Default INjector Good or bad?
hey how do i find out if my injectors are working right because my car is running really lean and i know it is getting proper fuel pressure to the fuel rail and it is getting spark. also i when i took the spark plugs out it had smoke flowing out of it. and smoke smelled like a weird burned smell.
thank you
brandon
Old Oct 17, 2007 | 08:54 PM
Default RE: INjector Good or bad?
the smoke is probably oil. But have you checked to make sure your o2 sensor is functioning. Cuz that would cuase a lean condition
Old Oct 17, 2007 | 09:03 PM
uuh ooh thats reeeally lean.
I thought generally o2 sensors would cause a rich condition?
Old Oct 18, 2007 | 06:20 AM
nick_200321's Avatar
if you hada bad injector it more than likely would make the car not only run lean, but run like horrible $hit, you wouldnt be getting enough fuel into the engine
Old Oct 18, 2007 | 07:47 AM
it does run horriable it doesent even start. it just cranks over and back fires alot while cranking and then the car will start but only stay at about 300-500rpms and it will buck and back fire like crazy.
Old Oct 18, 2007 | 07:48 AM
and the burning smelll smells more like metal burning then oil burning.
Old Oct 18, 2007 | 09:30 AM
ORIGINAL: thehintons06
it smells like that because your lean so your EGT's are way hotter than they should be.
I would check the ohms on all the injectors by pulling the clip out of it and touching to the two pins on the harness.
Old Oct 19, 2007 | 07:47 PM
chopper1's Avatar
Catalitic converter??? Would heat up and run bad.
O/2 sensor goes bad the car will usually richen up. What does the tail pipe look like. Clean, soot,
ryan51173
Jun 7, 2010 08:52 AM
nawgee
Oct 20, 2008 06:24 AM
agallardo
Oct 1, 2006 02:07 AM
gsxgogetter
May 26, 2005 01:58 PM
red.5gt
Oct 10, 2004 12:35 PM
