Injectors
Old Aug 8, 2006 | 05:33 AM
FastEd's Avatar
Default Injectors
I've got a '99 GS with a star turbo kit running at approx 9psi. It's got the after market fool-the mass air sensor thingy, the upgraded fuel pressure regulator, head studs, an MSD ignition module, and MSD hi-perf coil and plug wires, along with some suspension mods.
I do have of course, a lean fuel problem, and I'm lookings for soultions with ECU management in either using the stock injectors or just 1 step up.
Can I get a decent richer situation with an ECU programmer (which programmers work the best?) on my stock injectors, or should I upgrade to bigger ones + an ECU tunner?
Also, I will be running a boost controller in the future.
Thanks in advance...
Old Aug 8, 2006 | 09:27 AM
Default RE: Injectors
What kinda turbo comes in that kit? And is that all the mods that you have with it, is it intercooled (i hope so). Do you have a wideband that is telling you that it is lean. When does it run lean (idle, full boost, ect.)? sorry i know this is alot of questions, im just trying to find out what you need. As far as tuning goes. The Apex S-AFC II is really good for tuning A/F ratios. The problem is that you probably will need bigger injectors cuz im pretty sure that you will max the stock one out pretty quickly.
Old Aug 8, 2006 | 10:48 AM
ORIGINAL: TheEngineer
First thing... its spelled APEXi and your comment should say its really easy to tune AFRs because it is NOT a good tuning device it is only childs play. Its just easy to use.
Old Aug 8, 2006 | 11:18 AM
ORIGINAL: EMonz57
Well I really have no clue about it.....I just go on what I see you do, not like I have ever used this stuff myself.
Old Aug 8, 2006 | 07:47 PM
NESpeed's Avatar
ORIGINAL: EMonz57
Mike and I know this....I just need to spread the word.
Old Aug 8, 2006 | 09:44 PM
Tut tut engineer are you slipping on me?
Old Aug 9, 2006 | 03:18 AM
FastEd's Avatar
Yes, it's intercooled, and I didn't mention the cat-back exhaust
Laxstar785
Apr 28, 2005 11:03 AM
dbaxterjr
Mar 22, 2005 01:35 AM
osu girl
Jan 11, 2005 03:33 PM
antomx
Sep 4, 2004 07:19 PM
total_eclipse82
Jun 9, 2004 03:01 PM
