Its Stuck
Old Feb 17, 2008 | 10:46 PM
victim619's Avatar
Default Its Stuck
Today I raced a stupiod little civic that was reving like crazy at me thinking he was "COOL" I rolled down my window and asked what he had.......He had a Fart Can and intake so I raced him....Long story short I won but the thing is when I shift from 1st to 2nd it gets stuck when i push the gas again for example: I shift at 5000rpm then push the gas then it stays at 5000rpm and sounds like its stuck and the needle even stays around that for like a seconed then goes back down like normal. Its like im pushing the gas while shifting....which im not. Any Ideas?
Old Feb 17, 2008 | 10:58 PM
dorian7's Avatar
Default RE: Its Stuck
maybe your TB is getting stuck open. just take off the intake pipe or hose and w/ some carb cleaner whipe down the inside.
Old Feb 17, 2008 | 11:16 PM
victim619's Avatar
Could it be that the TB was due to be changed 10k ago lol?
Old Feb 17, 2008 | 11:34 PM
dorian7's Avatar
Changed? I am talking about the throttle body, but if the timing belt needs to be replaced (which I am guessing you are talking about) it needs to be done ASAP if it is over due.
Old Feb 18, 2008 | 06:21 AM
Iguessing its either the thottle cable or the trottle body. Also try and spray some wd40 on the trottle coil in the back. I used to have to do that im my old car
Old Feb 18, 2008 | 07:15 PM
tjbiker031's Avatar
who told you that your TB needed to be changed?
Old Feb 19, 2008 | 01:53 AM
victim619's Avatar
In the owners manuel im sure it says every 60k
Old Feb 19, 2008 | 06:18 AM
Yea the timing belt is something to keep up on given these motors are interference
rganders315
May 8, 2007 01:03 AM
JaysMontero
Oct 31, 2005 12:53 AM
reanimtdcowboy
Oct 21, 2005 01:35 PM
cucubana
May 1, 2005 01:36 PM
reallyaLS1chick
Apr 21, 2004 02:15 PM
