leaking water in my trunk
Old Dec 13, 2008 | 11:01 PM
banditboy21's Avatar
Default leaking water in my trunk
hello guys im new here and i own a 420a 98 eclipse and i have a problem. i keep getting water in the trunk and its not from the taillights or the hatch drain hoses so i cant find anywhere any other ideas would be appreciated
Old Dec 13, 2008 | 11:27 PM
dsm1990gsx's Avatar
Default RE: leaking water in my trunk
Check the weather strip around the hatch, you could have a small tear in it leting water leak into the trunk.
Old Dec 14, 2008 | 10:08 AM
i have checked the weatherstripping as well it seems like the water is coming in from behind the plastic sides when i pulled them off on both sides of the car and it is filling up the spare tire well
Old Dec 14, 2008 | 11:46 PM
shadowmancer's Avatar
check where the radio antenna is. if the seal there is busted or theres a dent around it. i had a similiar problem
Old Dec 15, 2008 | 12:24 AM
Dusty Eclipse's Avatar
Your sure the little hatch drain holes arent plugged shut with leaves or debris? It happens a lot, and isnt always obvious. Try sticking a hanger or something into them...
Old Dec 16, 2008 | 05:59 PM
^^X2
check your drains, i bet they are clogged
Old Dec 20, 2008 | 03:53 PM
it is not the drain hoses they run free. i am a experinced mechanic so i have looked at all the obvious places so it isnt obvious where the water is coming from. it was coming from the tailights at first but i sealed them up the only other place it may be coming from is thewiper fluid bottle i removed the other night and it was full of water and when i would spray the hatch with water i get water going down throught the wiper fluid bottle hose has anyone ever had this happen
Old Dec 29, 2008 | 02:26 PM
well guys i found the water leak its coming from the driver side of the car right where the bumper meets the quarter panel there is the body gap there and while spraying it with a hose and watching thee inside of the trunk i found the water to be seeping in through a seam that has 2 spot welds on it. so im going to use some body sealer to fix that but does anybody know is it a pain in the *** to remove the rear bumper cover
bayspeed
Aug 19, 2010 04:16 PM
elmiserable
Jan 20, 2009 08:18 PM
elmiserable
Jan 20, 2009 08:13 PM
shadowman2_1
Nov 15, 2004 06:21 PM
FatalJRA
Oct 30, 2004 05:32 AM
