leaking water
Old Oct 19, 2004 | 12:38 AM
shadowman2_1's Avatar
Default leaking water
I have a 1991 Montero with V-6 it has started to leak a lot of water from the back of the engine..I can not see where it is coming from..but can see it running onto the bell housing of the trans.. this leak will drain the cooling system in about 5 minutes.. the heater hoses look ok
Old Nov 15, 2004 | 06:19 PM
DarkManC's Avatar
Default RE: leaking water
You have a leak in your water cooling tube.
Old Nov 15, 2004 | 06:21 PM
DarkManC's Avatar
Sounds like your water cooling tube that runs across the top of the engine has a hole in it.
owensth
Aug 10, 2010 02:43 PM
Galvinized80
Jul 6, 2010 11:27 AM
banditboy21
Dec 29, 2008 02:26 PM
youngowner
Nov 4, 2007 12:41 PM
FatalJRA
Oct 30, 2004 05:32 AM
