Lifter tick in a DOHC??
Old Dec 22, 2006 | 01:22 PM
paintballproam's Avatar
Default Lifter tick in a DOHC??
Alright well we all know that the 4g63 is prone to lifter tick, my question is how can it get lifter tick? We just learned about lifters,cams,valves etc in auto class. Lifter tick occurs in engines with solid lifters when the rocker arm is not propperly tightened down causing it to tick on the top of the valve stem. Well..... there are no "lifters" in an over head cam motor according to my teacher, which makes perfect sense. So now i am very confused (so is my teacher) as to how an eclipse/talon can get lifter tick. Can some one explain this? Ive enclosed a picture of a "lifter" on the 4g63
[IMG]local://upfiles/7199/4E95D65C526648E1B9B02248479A99B5.jpg[/IMG]
[IMG]local://upfiles/7199/2B6B7F83EC4048388A198B7CF49CC501.jpg[/IMG]
Old Dec 22, 2006 | 02:22 PM
Default RE: Lifter tick in a DOHC??
Lifter tick is just a term it is not really lifters you here
Old Dec 22, 2006 | 02:28 PM
So isnt there a way to eliminate it on these cars? I mean, on a regular motor, you just tighten down the rocker arm
Old Dec 22, 2006 | 03:30 PM
racerx55's Avatar
change the lash adjuster (lifter)
Old Dec 22, 2006 | 03:35 PM
to bad there isnt just a way to adjust it without replacing the "lifters"
Old Dec 22, 2006 | 04:24 PM
racerx55's Avatar
theyre automatic adjusting, if they tap theyre either being starved for oil or they arent working right
Old Dec 22, 2006 | 04:29 PM
ORIGINAL: racerx55
Oil commonly. If they are starved from oil and the tick may never go away either. Basically tick and spun bearings are things oil has a good hand on
Old Dec 22, 2006 | 07:09 PM
Nubiebubie_GSX's Avatar
Well that was an interesting lesson.. i was arguing with somebody that these cars have lifters.
Old Dec 23, 2006 | 01:28 AM
racerx55's Avatar
its pretty much the same thing, it just doenst ride directly on the cam and has a different name
Randys
Aug 22, 2011 12:02 AM
cchrisj01
Jul 18, 2007 12:12 PM
pcfig
Jul 13, 2007 11:06 PM
pcfig
Jun 9, 2006 01:11 PM
wildwest
Jul 9, 2004 11:54 AM
