low fuel cut
Old Sep 6, 2008 | 04:23 PM
rico's Avatar
Default low fuel cut
ok so i gota 95 gst its got an injen intake and k&n filter, i have a big 16g turbo and a boost controler set a 10psi my problem is the car seems to hit fuel cut a 5k rpm im assuming it just needs to be tuned i dont really know.. this is how i got the car. i got a safc2 i just bought to tune it with and i just got some 550cc injectors imma put in it.. i just need some input on wheather thats wat it is or not thanks
Old Sep 6, 2008 | 06:10 PM
Default RE: low fuel cut
its prob a mix of the tune and a boost leak. Boost leaks cause premature boost cut. running only 10pSI shouldnt do it. BTW unless you have a wideband o2 and gauge you cant tune the car yourself.
Old Sep 7, 2008 | 11:51 AM
rico's Avatar
yea well imma have it tuned by a shop so i dont have to buy all that but imma replace all the hoses and check the connections as soon as i get the engine back in.. it did have some pretty shabby looking hoses on it for the piping
Old Sep 7, 2008 | 12:08 PM
buy or make a boost leak tester. they are cheap. and will save you countless hours in searching for a leak
Old Sep 7, 2008 | 12:45 PM
dsm1990gsx's Avatar
Go to www.vfaq.com and look under the intake section and there is a write up on how to make a boost leak tester and how to use it.
Old Sep 19, 2008 | 10:54 PM
rico's Avatar
but also the car will go to redline if i stay out of boost or only get like 1psi so idk if that is a boost leak or wats goinon
Old Sep 19, 2008 | 11:11 PM
yeah sounds like a boost leak. You wont hit fuel cut unless your under load. So if you stay off the turbo youll be fine. Do a boost leak test and be done with it lol
Old Sep 20, 2008 | 08:50 AM
rico's Avatar
ok thanks i still gotta finish rebuilding the engine and get it back in first..lol.. i alson got some pics of some vacume lines that havnt had ne hoses on them since i got the car imma post them later and see if you guys can tell me where they go.
Genosyne
Mar 29, 2007 09:07 AM
paintballproam
Jun 27, 2006 07:17 PM
razor27j
Aug 15, 2005 02:45 AM
