MBC Problems
Old Aug 3, 2007 | 01:56 AM
Pribs's Avatar
Default RE: MBC Problems
hallman mbc (es kit if that helps) and a greddy type rs bov recirculating
edit: I also saw on vfaq they ran a line from the mbc instead of to the turbo tee'd into the line coming off the bov. I have it running to the turbo not tee'd in. I dunno if that makes a difference
Old Aug 3, 2007 | 03:19 AM
silvercoupe97's Avatar
The way you have it is the recommended way, I also have mine that way.
Are you sure you have the mbc connected right?
Sorry about the bov question. I totally missed it in you sig.
MBC...The one that sticks out on the side goes to the wastegate and the other to the turbo compressor housing.
Old Aug 3, 2007 | 04:02 AM
2nd g eclipse gst's Avatar
could be the turbo, had the same prob with my car i thought it was the mbc but it turned out being my turbo was no good
Old Aug 3, 2007 | 11:18 AM
Pribs's Avatar
ORIGINAL: 2nd g eclipse gst
Sh*t if thats the case I'm screwed I'm flat broke. How do I figure out if its the turbo or the MBC? Because I do have it hooked up right cuz like I said I had it dialed into 15psi then it just went back to factory and pretended like the mbc wasnt there w/o me changing anything
edit: if my turbo is going up would that have anything to do with my terrible gas milage? I'm gettin 230 to a tank at best
Old Aug 3, 2007 | 02:32 PM
check and see if you have any shaft play on ur turbo
Old Aug 4, 2007 | 12:44 PM
Pribs's Avatar
well my turbine wheel is scraped up on the edges it looks like hell. and the wheel wiggles a bit when i move it. So I think its done. I mean it works right now at 12 psi but the last thing I want is a piece of that wheel to break off and go into my engine. So I think that was the problem
Old Aug 4, 2007 | 12:46 PM
Pribs's Avatar
out of curiosity cana bad turbo give poor gas milage? I no this could be a dumb question but I am still new to this
get435
Dec 22, 2005 10:59 AM
DixonsGst
Oct 30, 2005 09:47 PM
99clipsgst
15
Aug 25, 2005 04:41 PM
USCordia
Aug 13, 2005 06:41 PM
drewblueeye
Jul 9, 2005 03:42 AM
