MILEAGE AND RELIABILITY?
Hey guys,
Let me say thanks alot first off. You all have been a big help since i have joined last week. Anyways, there is a very clean bone stock 98 gst for sale. The guy is asking $5500. The only problem is that its got 155,000 mi.
What is the typical life of these engines, and if the engine runs strong with no problems will modding it be o.k.? What do you guys think? I spoke to a couple shops about rebuilding but they both said if its running fine then modding would be o.k. I thought with those kind of miles that id need to rebuild.
Please give me your input.
Thanks,
Thanks,
with that many miles on it i'd definatly check for any kind of shifting problems, clutch sticking, and any ticking sound what so ever. crankwalk is the only thing i'd be worried about with that kind of mielage. granted that not every engine will crankwalk but if this car is one of the unlucky than the time is coming up for it to do so. ask him about how well he maintined it (oil changes etc), any ticking or knocking from the engine bay. if all of those are covered you should be a ok. obviously you want to check for anything like a blown head gasktet (look under the oil cap for any white residue. when you test drive it make sure you keep an eye on all the vitals (boost, water temp, suttering, bogging etc). good luck.
ORIGINAL: RCJr9186
Ive seen plenty of these engine go over 200k but its all on the owner. If it has been taken care of then you shouldnt have any problems. One of the major things with these is they are getting older and rust also becomes and issue. So thats another thing to check for. And yes modding is fine as long as you just keep up on the maintenance
ORIGINAL: TheEngineer
Hey guys another ? in regards to crankwalk. I did a search and read that the 1st gen 4G63T engines didnt have crankwalk. Any truth to this? And if so, would putting a pre- 95 engine in a 95+ be o.k. or will it work ande pass smog because i dont believe it is obd 2, if that even matters.
Thanks,
Thanks,
ORIGINAL: sk8dudety
also is 5500 a fair asking price with that many miles? i would think u could drop that down to at least 5k
Thanks,
JJT
03-23-2007 03:13 PM
