missfire
Old Feb 15, 2006 | 12:35 AM
georgegsx's Avatar
Default missfire
i have a misfire i have replaced the plugs wires coilpack fule filter checked my compression... everthing i can think of???? i need help
Old Feb 15, 2006 | 12:48 AM
NESpeed's Avatar
Default RE: missfire
How bad of a misfire?
Old Feb 15, 2006 | 12:53 AM
Sanguinius's Avatar
First you need to find the missing cylinder. With the engine running pull each spark plug wire one at a time when you find the one that the engine sound doesn't change when you pull it then that is the cylinder that is missing. Once you've found the cylinder that is missing take the spark plug out and put it in the wire now touch the end of the plug to bare metal and crank the engine to see if there actually is spark getting to the plug.
Gstfat
Mar 27, 2007 08:02 PM
wswen842
Apr 14, 2006 11:30 AM
1990GSX
1st Generation
31
Jan 16, 2006 08:21 PM
drith
Jan 3, 2006 12:48 AM
Kaeslice
Feb 16, 2005 08:05 PM
