my car is running like $hit????
Old Nov 26, 2007 | 04:58 PM
bestwiseguy's Avatar
Default RE: my car is running like $hit????
Is it still putting out white smoke?
Old Nov 26, 2007 | 05:45 PM
get435's Avatar
I had the idle issues happen not to long ago blew a few vac hoses loose i would check all of yours.
Old Nov 26, 2007 | 06:20 PM
dsm1990gsx's Avatar
Check all your vacuum hoses like what get435 said and also check the iac, these cars have issues w/ those things. Also check your timing and try ajusting the idle if you can and make sure your throttle cable isnt stuck or hanging open.
Old Nov 26, 2007 | 07:39 PM
sprtcarmaniak's Avatar
its idling at 4000.. the rpm is to high to have white smoke..
i just put my boost leak checker and, i have a little boost leak but nothing huge...
Old Nov 26, 2007 | 07:58 PM
dsm1990gsx's Avatar
ORIGINAL: dsm1990gsx
^^^Check your throttle linkage and iac valve.
Old Nov 26, 2007 | 07:59 PM
what is the iac????
Old Nov 26, 2007 | 08:00 PM
the idle screw???
get435's Avatar
even thought it is white smoke i would then do a compression test. Did you notice if it was running a little hot at all? It dose not make since that it would blow white smoke unless you are burning coolant. Are you sure it was fuel that came out of the exhaust or water that smelled like rich exhaust?
Edit:
Sorry had to run out and take pics
Old Nov 26, 2007 | 08:08 PM
dsm1990gsx's Avatar
ORIGINAL: sprtcarmaniak
what is the iac????
Idle air control valve
Old Nov 26, 2007 | 08:09 PM
dsm1990gsx's Avatar
the idle screw???
Try turning it down but make sure the throttle cable isnt hanging open or binding.
