need help fast
Old Sep 28, 2006 | 03:58 PM
Default RE: need help fast
well if the lights on then get the code. That should tell you what you need to know. Head over to autozone or something and they can run the code for you
Old Sep 28, 2006 | 04:03 PM
darknigh7th's Avatar
i know one of the codes is air/fuel i just don't know how to find it
Old Sep 28, 2006 | 05:41 PM
did you write down the code #?
Old Sep 28, 2006 | 06:46 PM
well right now i had one that said P1400 i don't know what it is, any help would be great
Old Sep 28, 2006 | 06:56 PM
it says Manifold Differential Pressure Sensor Circuit Malfunction
Old Sep 28, 2006 | 07:43 PM
Nubiebubie_GSX's Avatar
I had that error code, but it did not affect the car idle or driveability. It gave that error code because i had the Map sensor removed since i had no place to connect it to at the time. 1 gen intake doesn't have a stock spot for it. I was reading else where and apparently its job isnt all to important. If your MAS fails on you, your car goes into limp mode and rely on the Map sensor and its other purpose is to monitor the EGR system. Now since i have the MAP sensor hooked up it notice my EGR is not workin properly and so gives me that error code. Another aspect i dont care about. Well dont quote me its something i read elsewhere.
ProjectDrknss
Aug 9, 2007 01:39 AM
green_eclipse94
Jan 15, 2006 08:19 PM
shade
Jan 26, 2005 03:20 PM
sreps
Jan 21, 2005 08:55 PM
unplugged_nate
Jul 2, 2004 11:32 PM
