need help with some plugs
Old Jul 28, 2009 | 04:30 PM
laurenk's Avatar
Default need help with some plugs
i have a 96 eclipse gs-t that i've been rebuilding for almost 2 years now, and its almost done.. ive been looking up sensors and plugs and have figured out most of them, but i have some strays i'm not too sure about. if anybody knows what these are and where they go thatd be awesome if you could help me out..
this plug is to the left of my throttle body and upper IC piping
this is to the right of my intake manifold
this is also to the right of my intake manifold
and this is a stray hose laying around, im not sure what it could go to
thanks guys,
lauren
Old Jul 28, 2009 | 05:25 PM
dsm1990gsx's Avatar
The first connector looks like an isc connector.
The 3rd pic I believe is a capacitor and can just be bolted down w/ the ground on the back of the intake manifold.
The 5th pic looks like the connector to the coil pack.
The hose is an a/c line.
Remeber I've never owned a 2g turbo so I'm kinda going off my 1g engine lol. Hope I helped a little.
Old Jul 28, 2009 | 08:52 PM
laurenk's Avatar
yes thank you so what do i do with the first pic, the plug? i dont see any home for it anywhere
Old Jul 28, 2009 | 09:07 PM
dsm1990gsx's Avatar
There should be an idle speed controller on your throttle body. Thats what that connector looks like and should be 6 wires. Can you get more pics of that area?
Old Jul 29, 2009 | 11:47 AM
laurenk's Avatar
yess i will post them later today
Old Jul 31, 2009 | 07:30 PM
laurenk's Avatar
so i figured out its actually my "front o2 sensor" but i cant find anywhere to connect it
Old Jul 31, 2009 | 07:44 PM
dsm1990gsx's Avatar
Can you get more pics?
Old Aug 1, 2009 | 10:46 AM
spyderSAM's Avatar
for the 1st its the front o2 sensor and all you need to do is start at the sensor which is just under the exhaust manifold, trace the wire, and plug the two together. The wire coming from the o2 sensor is usually routed on top of the exhaust manifold heat shield and they connect somewhere under the thermostat/ upper intercooler pipe area. If you dont have a heat shield you can zip tie it to the radiator fan housing and route it across that way.
fungusboy
Dec 15, 2012 03:33 AM
MitsE03
Jan 19, 2007 09:28 AM
Arioch
Nov 1, 2006 06:29 PM
Richie03
Dec 12, 2005 11:14 PM
1998blackgst 240
Apr 12, 2005 12:56 PM
