Need some Major Help...
Old Dec 8, 2006 | 01:29 PM
juanvan's Avatar
Default Need some Major Help...
Ok I am a little lost on this whole engine swap, and does not make ne sence..
Its a 95 2.0 Non-Turbo STD Shift
The engine, has been swapped out from a dodge advenger, same engine..
Problem: The car will start, and run for 10-20 mins, but then will Die out and won't start till the Next day.
When it shuts down like this, there is:
No Spark and No Gas.
The PCM has been replaced, thinking it was bad, but does the Same thing.
Other things replaced:
Crank Position Sensor;
Cam Shaft Sensor;
Temp Sensor;
Oil Pressure Sensor;
Connected or unconnected they do the same thing.
Anyone have any Idea what might be the problem?? Something need to be reset...
Old Dec 8, 2006 | 02:28 PM
Default RE: Need some Major Help...
ECU maybe
Old Dec 8, 2006 | 02:49 PM
The advengers used the 420a??
Old Dec 8, 2006 | 03:09 PM
RCJr9186's Avatar
yup
Old Dec 8, 2006 | 03:17 PM
juanvan's Avatar
Is there anyway to reset the ECU or troubleshoot it?
Old Dec 8, 2006 | 03:35 PM
unfortunetely the ECU is the hardest thing to troubleshoot. You can take it out and open it up to see if something got fried. Cuz there have been cases where something in it just blew up. So may see if you blew a resistor or something. But the only way to really know is replacement. It could also be a bad ground somewhere
Old Dec 8, 2006 | 03:52 PM
juanvan's Avatar
Ok I will open it up and see whats going on in there..
Thanks for the info so far!
HoldFast98
Aug 20, 2009 08:17 AM
smarsenal
Apr 15, 2008 05:27 PM
Jpos
Apr 14, 2008 06:30 PM
ECLIPSE420
Jun 29, 2006 10:26 AM
Nubiebubie_GSX
Jun 20, 2006 11:08 PM
