new alt.?
Old Dec 22, 2007 | 03:58 PM
tjbiker031's Avatar
Default new alt.?
ok so i noticed a few days ago on my way to work in the morning that when i sit at idle my headlights dim down a little, and when i rev up the engine the lights come back up to normal. is this normal or does my charging system need to be serviced?
Old Dec 22, 2007 | 11:45 PM
silvercoupe97's Avatar
Default RE: new alt.?
It's normal on these old motor components. I don't think your alternator is bad unless you've been having issues with it causing your car to die on you at a stop.
You may want to change out your battery if it's old. Another consideration is the voltage draw. If you have a system, there's your problem. That's a huge voltage draw, one that our little 75 - 90 amp (at the highest) alternator can barely handle.
Old Dec 23, 2007 | 02:55 AM
Check grounds. If you want to make that a little better, get a grounding kit.
flunnky
Feb 18, 2007 02:25 AM
keithscianna
Jan 14, 2007 11:43 AM
Frost89
Jan 11, 2007 01:35 AM
DanD
Aug 30, 2006 01:04 PM
embassy17
Apr 24, 2006 06:14 PM
