New HKS SSQV on 95 gst
Old Oct 24, 2007 | 04:10 PM
  #41
ProjectDrknss's Avatar
Default RE: New HKS SSQV on 95 gst
hmmm reading all these post is interesting. so what would you recommend for an aftermarket bov what will work well with the recirc kit? seems like greddy is the way...
Old Oct 24, 2007 | 04:26 PM
  #42
sk8dudety's Avatar
i would say so yea, that seems to be the most popular on this thread
Old Oct 24, 2007 | 05:05 PM
  #43
CelciuS209's Avatar
Yea Hks Is hated. on these forums. for some strage reason lol
Old Oct 24, 2007 | 05:55 PM
  #44
Its not hated, its a great BOV, just not for these cars.
Greddy Type RS is a good one : )
Old Oct 24, 2007 | 06:24 PM
  #45
ORIGINAL: CelciuS209
I love the HKS valve it is just not a good part for these cars unless you run high boost like over 25PSI and run speed dencity which they dont come with stock and is very costly so it causes problems with your ECU and AFR's and robs you HP, spool time, and drive ability.
The one I would recommend over the greddy stuff is Forge BOVs they are great for high or low HP\boost levels. I personally like the Forge RS
Old Oct 24, 2007 | 07:05 PM
  #46
CelciuS209's Avatar
Yea i got you guys how much boost can we run on a stock gst safe
Old Oct 24, 2007 | 07:07 PM
  #47
Bov will leak at 12, replace that and you can crank it up to 16-17, change the fuel pump and run 18-19, get an EVO III 16g,660cc injectors and SAFC II and you can run 23ish. Stock internals can handle a MAX of 25 and a max of 400whp
Old Oct 24, 2007 | 07:22 PM
  #48
ORIGINAL: Sebba
keep in mind these are ball park figures and some things require some other supporting mods to run Boost levels 18 and up
Old Oct 24, 2007 | 08:32 PM
  #49
CelciuS209's Avatar
so your saying mine can run 16-18 wit my eclipse? am getting the 16g soon after that i will crank up more? in the 23ish?
Old Oct 24, 2007 | 08:37 PM
  #50
Things that are needed to run 16-18 are:
Intake
Exhaust
MBC
Boost Gauge
190lph fuel pump
BOV
To run more:
660cc Injectors (recomended Denso)
ACT 2600 clutch w/ a street disc
Apexi SAFC II
Wideband o2 gauge
EVO III 16g turbo
Decent FMIC (Not eBay)
Am i missing anything?
It is also recomended that before you start modding heavily that you make sure you have no fluid leaks of any kind, your compression numbers are good, you change your plugs and wires, and your timing belt has been changed within the last 60k miles.
