No horn when arming
Old Dec 14, 2005 | 08:30 PM
cpudoc6's Avatar
Default No horn when arming
May be easy, but my horn wont chirp when I lock or unlock the doors. It also does not sound when the alarm goes off, the lights flash but no sound.... I tried what my owners manuel says ( hold lock for 4-10 secs and press the unlock and release both) but no luck.
Any ideas?
Thanks,
Ron
Old Dec 14, 2005 | 08:53 PM
Jchristopher's Avatar
Default RE: No horn when arming
what happened on mine was the wire leading to the horn in the front of the car had come out of the horn it self. check the horn usually located near the bumber in the front of the car right on the inside when you open your hood...i cut mine off and re-ran a wire that was longer so that is was not able to be pulled out again. it was easy to do, let me know if this helps
Old Dec 14, 2005 | 09:25 PM
cpudoc6's Avatar
My horn works from the steering wheel, did yours?
Old Dec 16, 2005 | 04:40 PM
Patrick's Avatar
Administrator
what gen eclipsE?
Old Dec 17, 2005 | 02:18 AM
cpudoc6's Avatar
2001 I guess it g3, anyway the spade connector on the alarm horn was broken. I put a new connector on and all is well.
Thanks for the replies
Ron B
n0c7
Oct 4, 2012 11:34 PM
fizzwhiz1
May 23, 2010 08:42 PM
jimbowe
Mar 16, 2006 07:35 AM
tlara67
Aug 8, 2005 12:29 AM
mike96eclipseRS
Oct 11, 2004 10:31 PM
