no spark for cyl 1 and 4
It MUST be a coil pack. If you were getting no spark on all id say the distrubuter. If you were getting no on 1 then id say wire or plug. But where your not getting it on 1 AND 4 i find it an odd coincidence they they happen to be on the same coil pack. try replacing it.
well i know 110% its not the coil pack cause i bought a new coil and replace it with the 1n4 coil side(that didnt work before)...still no spark but only on 2n3...so what if mabe autozone gave me some pos...i thought so then i swicthed the coil with my old one that worked(2n3) to 1n4 side...n the new coil from autozone to 2n3 side....still same results only 2n3 sparks...tested them with working plugs n wires...tested the continuity on the transistor and all of the wiresbeeb but not an hold beeb...any ideas?
ORIGINAL: clips69
What was the last thing you did before all this started?
the pins on the transistor all beebed when i tested it with a 1.5v battery sorta odd i think?...but all of them didnt hold a beeb...i guess usaully with checking continuity it should hold a beeb not just beeb...but if it just beebed instead of a hold beeb is the transistor still good?
lloydjv
Jul 17, 2022 09:15 PM
