no spark for cyl 1 and 4
Old May 26, 2008 | 05:29 PM
clips69's Avatar
Default no spark for cyl 1 and 4
i have a 98 gst that only sparks on 2 n 3...ignition coil,plugs and wires are good...could it be the ignition control module causing only the 2 n 3 coil side to sparK?
Old May 27, 2008 | 04:20 PM
Default RE: no spark for cyl 1 and 4
It MUST be a coil pack. If you were getting no spark on all id say the distrubuter. If you were getting no on 1 then id say wire or plug. But where your not getting it on 1 AND 4 i find it an odd coincidence they they happen to be on the same coil pack. try replacing it.
Old May 27, 2008 | 06:38 PM
Yeah dude one of them is gone.
Old May 28, 2008 | 08:12 AM
clips69's Avatar
well i know 110% its not the coil pack cause i bought a new coil and replace it with the 1n4 coil side(that didnt work before)...still no spark but only on 2n3...so what if mabe autozone gave me some pos...i thought so then i swicthed the coil with my old one that worked(2n3) to 1n4 side...n the new coil from autozone to 2n3 side....still same results only 2n3 sparks...tested them with working plugs n wires...tested the continuity on the transistor and all of the wiresbeeb but not an hold beeb...any ideas?
Old May 29, 2008 | 05:43 AM
silvercoupe97's Avatar
ORIGINAL: clips69
Can you clarify this. You tested the transistor......and they are fine?
What was the last thing you did before all this started?
Old May 30, 2008 | 09:06 AM
clips69's Avatar
the pins on the transistor all beebed when i tested it with a 1.5v battery sorta odd i think?...but all of them didnt hold a beeb...i guess usaully with checking continuity it should hold a beeb not just beeb...but if it just beebed instead of a hold beeb is the transistor still good?
lloydjv
Jul 17, 2022 09:15 PM
cchhiipp
Sep 5, 2011 07:13 PM
wswen842
Apr 14, 2006 11:30 AM
jsnichols1
Feb 10, 2005 01:40 AM
dirk
May 1, 2004 02:43 PM
