no spark no fuel cont.
Old Jun 17, 2007 | 02:24 PM
brknhrtdpimp1489's Avatar
Default no spark no fuel cont.
alright guys im sure a few of you probably remember a while back i was having trouble with my talon not getting fuel or spark and we pretty much all narrowed it down to the ecu...ive replaced the crank and cam position sensors and ive replaced the asd relay...well i had a guy interested in the car and he came out and brought the ecu off of his gs eclipse and still wont start...the fuel rail would spit a little fuel out and then that was about it...any ideas cuz man im seriously lost here...
Old Jun 17, 2007 | 02:52 PM
Default RE: no spark no fuel cont.
The wrong ECU!
Old Jun 17, 2007 | 03:12 PM
racerx55's Avatar
maybe he intentionally brought a bad one so he can get the car cheaper
i once bought a car for $100 because it didnt run and he couldnt figure it out, i hooked the coil wire back on and drove it home
Old Jun 17, 2007 | 09:41 PM
96eclipsedohc's Avatar
its the ecu, 99 % sure, the exact same thing happened to my car...and when you buy one, get it from chrysler, its cheaper
Old Jun 18, 2007 | 03:58 PM
what are the odds it could be a wiring problem...like mabe i have a power wire grounding out on a ground somewhere b/c they wore a spot out of the plastic covering on the wire...its gotta be the ecu or a wiring problem b/c ive done everythiing else it could possibly be...
Old Jun 18, 2007 | 03:59 PM
Thats possible
Old Jun 18, 2007 | 04:14 PM
well this is exactly what happened to mine, i bought the car and it had a idle problem, then i drove the car for about 2 weeks and then the check engine and the battery light come on..then it would start cutting out and the battery and the check engine light would go on and go off when it would cut out, and then one morning and i let it run for about 2 minutes, it cut out like 3 times, and just died..well i thought i was the coil pack, changed it, nothing, then i put a brand new ecu from chyrsler on it ($404.00) i think..and it started right up, no check engine light or battery light, its been running good ever since..just something for you to think about
gjones709
Feb 17, 2011 09:54 PM
kornfandude
Feb 21, 2010 07:32 AM
l-e-o-n-a-r-d
1st Generation
Jul 2, 2009 06:04 PM
brknhrtdpimp1489
May 9, 2007 12:08 PM
1rippinGT
Jun 30, 2004 02:14 AM
