No Spark? Where to start?
1995 GST, was running fine before blowing a timing belt. New head and belt has now been installed but it won't start - no fire to plugs. Engine cranks over but there is no spark.. Crank and Cam sensors are plugged in, as is everything else I can think to check. Any ideas on where to start to determine the problem?
I'm new here, but I've been around the block a few times.. Thanks
RE: No Spark? Where to start?
There's more to the story now.. After replacing the bad Crankshaft Sensor, it would start, but only run on 2 cylinders. Tested the Camshaft sensor, and it was broken too!. Replaced the camshaft sensor, and that should be it right? No. Started it again and it hit on all four but ran terribly rough at low rpm and would not idle. It was a intake manifold vacuum leak - parts store gave me the wrong intake manifold gasket. Fixed that and now everything seems to be ok.
marvinr
04-22-2007 03:03 PM
