No Spark? Where to start?
Old Nov 22, 2004 | 04:01 PM
red.5gt's Avatar
Default No Spark? Where to start?
1995 GST, was running fine before blowing a timing belt. New head and belt has now been installed but it won't start - no fire to plugs. Engine cranks over but there is no spark.. Crank and Cam sensors are plugged in, as is everything else I can think to check. Any ideas on where to start to determine the problem?
I'm new here, but I've been around the block a few times.. Thanks
Old Nov 22, 2004 | 05:18 PM
96awd's Avatar
Default RE: No Spark? Where to start?
check the distributor-power transistors-igintion coil-spark plugs- plug wires
Old Nov 24, 2004 | 07:18 PM
red.5gt's Avatar
It was the crankshaft sensor. The backside of it was completely broken off. It must've taken a hit from the belts when they shredded.
Old Dec 2, 2004 | 12:16 PM
vertstanggt's Avatar
sigh, it's always a sensor or something like that[:-] Kinda miss the old days where you could start a car with no battery by pushing it down a hill and popping the clutch.
Old Dec 2, 2004 | 03:08 PM
red.5gt's Avatar
There's more to the story now.. After replacing the bad Crankshaft Sensor, it would start, but only run on 2 cylinders. Tested the Camshaft sensor, and it was broken too!. Replaced the camshaft sensor, and that should be it right? No. Started it again and it hit on all four but ran terribly rough at low rpm and would not idle. It was a intake manifold vacuum leak - parts store gave me the wrong intake manifold gasket. Fixed that and now everything seems to be ok.
Old Dec 2, 2004 | 08:43 PM
LOL, oh man, never simple is it? Glad you got it figured out though.
LancerLot1
Aug 24, 2010 04:35 PM
atomix3
Sep 23, 2009 05:48 PM
ehawk24
Nov 29, 2008 11:31 PM
workmanls
Jul 23, 2004 04:58 PM
