NO START
Old Jan 22, 2009 | 02:42 PM
MCKINNEY7248's Avatar
Default NO START
OK THIS 1992 ECLIPSE 2.0 NONTURBO THEAlternator WENT OUT SO I REPLACED IT AND FOUND THE FRONT COVER FOR THE ENGINE WAS CRACKED THE TENSIONER FOR THE AC COMPRESSOR HAD BEEN RUBBING THE FRONT COVER AND IT WAS FULL OF OIL THE FRONT SEAL AND VALVE COVER WAS LEAKING SO I RELPACED BOTH AND THE TIMING BELT AND TENSIONERS NOW THE CAR WILL START AND RUN ALL DAY IF YOU WANT IT TO BUT THE FIRST TIME YOU SHUT IT OFF IT WONT START AGAIN UNTILL THE MOTOR COOLS OFF MAYBE I HAVE A HEAT SOAK PROBLEM WITH SOME MODULE OR SENSOR UNDER THE HOOD IM NOT SURE WHAT TO DO TO FIX THIS PROBLEM SOMEONE PLEASE HELP ME.
THANKS
mysticrythms
Mar 19, 2014 08:17 PM
dahoopd
Nov 4, 2010 08:10 PM
