Obd p1390
This is the direct definition of this code
Mitsubishi DTC P1390 - Timing Belt Skipped 1 Tooth or More.
Probable Causes,
-Timing belt improperly installed
-Camshaft position sensor improperly installed
-Camshaft position sensor connector improperly connected
-Crankshaft position sensor connector improperly connected
-Camshaft's relative position not relearned after one of the following have been serviced: Camshaft, Camshaft sprocket, timing belt tension-er, cylinder head, head gasket, crankshaft sprocket, crankshaft cylinder block or the PCM.
Sounds like something to do with the timing belt it self. You can go to any Autozone or Checker and ask for a code reader (they will let you use it for free) and it will show this code again. You can also reset the cars computer with the code reader to see if it comes back with the same code.
Probable Causes,
Damian Wolf
Sep 10, 2013 08:58 PM
