oil`everywhere!!! help
Old Jan 15, 2007 | 01:19 AM
gst4me's Avatar
Default oil`everywhere!!! help
hey guys i was on my way to a car show today just ridin along on the turnpike and someone cut in font of me so i got over and hit a little bit of boost. Then the car started acting really bad... noooooo power. temp seemed to be fine...... so i pulled over. i went to restart it and it made like a rubbing noise so i stopped.... i popped the hood and checked the oil...... LOW!!! i got on the ground on the driver's side and oil was everywhere!!!! all over the suspension and the under carriage. i just changed the oil pan gasket 2 weeksago and its been fine till now..... i need help.... c'mon guys.... i havent been able to take a look at it yet cuz it didnt get towed back till late..... what else could it be?
Old Jan 15, 2007 | 01:40 AM
I Drive Naked's Avatar
Default RE: oil`everywhere!!! help
If it covered the suspension like it did, the possiblity of it being the crank seal exists.
Just be patient and wait until you have some light, then check around the crank pulley for signs of leaks.
You'll have to clean the mess off, then wait for it to leak again.
Old Jan 15, 2007 | 01:44 AM
gst4me's Avatar
if so how hard is that to fix???
Old Jan 15, 2007 | 01:46 AM
not tooo bad.
I did one on a cavalier.
take the wheel off, pull the axle and hub, pull the belts off, remove the crank pulley, you might need a special tool for the seal itself, not sure.
Old Jan 15, 2007 | 01:54 AM
gst4me's Avatar
ok man thanx.. good lookin out!!! if anyone has any more ideas on what it is lemme know.....
Old Jan 15, 2007 | 04:09 AM
gst4me's Avatar
anyone?
Old Jan 15, 2007 | 06:56 AM
racerx55's Avatar
howbout double gaskets on the oil filter... that will only leak badat higher rpm.Ive seen it overlooked a thousand times. If it started losing power from low oil your probly already on your way to a messed up engine.[:'(]
Old Jan 15, 2007 | 01:45 PM
gst4me's Avatar
ok.... dam i hope its not too bad..... if so imma have to save up and go ahead and do my stroker kit.......
keyz_96
Jul 14, 2011 07:20 PM
beerbaron
Nov 12, 2009 11:34 AM
Simss
Jan 4, 2007 03:20 PM
cintil8
Feb 16, 2006 04:35 PM
Sanguinius
Sep 18, 2005 04:17 AM
