Oily plugs
Old Jul 4, 2007 | 01:44 AM
Kaede.Noir's Avatar
Default Oily plugs
Seriously lately, all things have sucked BAAADLY! like EVERYLIL THING!!!, and so i go "Ok, im gonna have some myself time, me and my car, a lil tune up, poor mileage a bit of rough idle, i should get it running well.... WRRONG! oily $&#@ plugs!!!!... i know what this means, but i cant afford it, nor dont want it to be like this...... piston rings right? maybe some lil prob with the valves? tiny one?
Old Jul 4, 2007 | 02:21 AM
sk8dudety's Avatar
Default RE: Oily plugs
i thought oily plugs just meant a bad gasket... i could be wrong though...
Old Jul 4, 2007 | 02:23 AM
I Drive Naked's Avatar
Valve cover gasket is leaking buddy.
Theres seals around the spark plug holes on the valve cover.
when those seals go out, oil leaks down into the plug chamber.
Change your VC gasket and you'll be fine.
Its a $20 part from O'Reilly's.
Old Jul 4, 2007 | 03:03 AM
Kaede.Noir's Avatar
Im seriously gonna do that, that and run a vacuum test and compression test to make sure, thnx josh, SERIOUSLY, the only positive thing about today
Old Jul 4, 2007 | 06:06 AM
silvercoupe97's Avatar
Are you blowing smoke out the tailpipe? Was the oil on the top of the plug or the tip of the plug (the combustion side)? When was the last time you changed out the PCV? Do you get a CEL at all?
If you are blowing smoke then it could be the gasket or piston rings.
If you the oil is on the top part of the plug, then Josh's fix will work great.
You could have an open PCV allowing oil to get into the chamber (more than normal) and it could also cause a vacuum leak if it is open and give you poor idle issues.
Old Jul 4, 2007 | 09:59 PM
Kaede.Noir's Avatar
Allright silver thank you sooo much for your feedback you have ALWAYS been a lifesaver, i am NOT blowing smoke out of the tailpipe, im totally clear, the oil is on the spark side, but theres and amber/oil like burnt stain from the porcelain side, its weird ill post pics later, pvc change.... NOOOO idea seriously... and no, not cel at all... just a rough idle which has almost dissapeared after the spark plug change, and a LIL bit of knocking? i dunno, a lil nuts sound that at around 3-4k rpms that goes away, kinda like when the cars get hot or dont have oil (which is not my situation any of those 2). Imma change the gaskets soon to make 100% sure about it, thnx guys again
jetblack
Jan 1, 2015 02:44 PM
Garvinder
Feb 22, 2014 07:39 PM
klas
Jul 20, 2011 02:12 PM
hagar
Dec 9, 2005 02:34 PM
nimby
May 13, 2004 04:28 PM
