porting and flapper
Old Sep 6, 2007 | 02:36 PM
Gstfat's Avatar
Default porting and flapper
since you guys know my E316G is overboosting(boost creep),i just wanted to know if anyone knows a good shop in miami florida that can do that job?do i buy a flapper or does the shop usually have one?
Old Sep 6, 2007 | 02:39 PM
Default RE: porting and flapper
Better than that.. the 34mm will still creep a little. If you ask me i say weld that shut.. and get an external wastegate tapped into your exhaust manifold. That will work like a charm
Old Sep 6, 2007 | 02:40 PM
Gstfat's Avatar
which external wastgate would you reccommend?if i do that should i still port it?
Old Sep 6, 2007 | 02:41 PM
No you dont need to port it because its being welded shut... but you can port the in/outlet : )
Tial 38mm wastegate is awesome.
Old Sep 6, 2007 | 02:43 PM
Gstfat's Avatar
whats a good price for that?do you think any good shop would be able to do that?
Old Sep 6, 2007 | 02:44 PM
Gstfat's Avatar
and when you say exhaust manifolf you do mean turbo manifold right?
Old Sep 6, 2007 | 02:48 PM
Yes sir. You can either buy another one with an external wastegate attachment... seen on www.slowboyracing.com or you can have a welder fabricate one.. but thast ghetto and you might crack it. They also have Tial wastegates.
To weld the flapper shut they shouldnt charge you much... takes like 2 mins
sk8dudety
Oct 13, 2007 09:02 AM
thehintons06
Sep 22, 2006 11:14 PM
GSX~speedjunkie~
Jul 19, 2005 05:47 PM
BurntGSX
Mar 17, 2005 03:57 AM
ForceFed4
Apr 16, 2004 01:47 PM
