question
Old Apr 21, 2004 | 06:29 PM
SaturnRacing's Avatar
Default question
can some one tell me what a stock 96 rs should run in th 1/4 mile. I got a couple little mods done and havent ran it yet. Also, i got a bad grinding coming from the tranny. How would i know if its the clutch (throw out bearing) or a dif. pin failure? It only makes the noise when i dont have the clutch down. Its not being driven and got plenty of time for answers please...<edited><editID>SaturnRacing</editID><editDate>38098.6874652778</editDate></edited>
Old Apr 22, 2004 | 12:41 PM
Spyderman9803's Avatar
Default question
high 14's-low 15's depending on driver
Old Apr 22, 2004 | 11:48 PM
SpyderGS's Avatar
Default question
Is it like a gear grinding noise or another kind of grinding noise? Also, do you mean clutch engaged or disengaged, and does it grind when in neutral?</P>
Old Apr 25, 2004 | 01:32 AM
Default question
No it doesnt do it grind when i have the clutch engaged. Aslo if its not engaged, it will make a grinding noise in neutral. But when driving, it will go away when i get it into 5th. Is it the clust or what?
Old Apr 26, 2004 | 03:55 PM
Default question
hmm....not sure there.....The only car I have ever heard make a grinding noise in neutral is a Supra. Many of them did it from the factory with their stock clutches.
oasis
Jan 23, 2005 05:43 PM
quicken
Mar 6, 2004 11:37 AM
override1059
Feb 10, 2004 09:37 PM
Som1Dies2Nite
Dec 1, 2003 08:47 PM
2fast4u
Sep 6, 2003 06:44 PM
