question???????
question???????
hey i have a 95 mitsubishi eclipse 5 spd it letting out white smoke but it smells like its running rich i the car runs hard like theres no problem now it is cold outside and there aftermarket muffler one it can anyone help the white smoke is saying head gasket but the smell and the fact it run good isnt ?????
RE: question???????
White smoke is water, blue is oil, black means your running rich. The question you need to answer is where the water is coming from. Like earlier posted, there is a good chance that you have a head gasket leak, but that may not be the case. The reason I say this is your other comment about it being cold in your area.
If your area has suddenly gotten cold, you may be experiencing water in the gas. This could have come from a recent fill up, or if your gas tank was under half and you got a sudden drop in temp, water could have condensated in you tank.
You stated you were going to do a compression check...GREAT! If that shows no problem, put a bottle of "heat" or related product through the system and fill er up with some good fuel.
Good luck.
Good luck.
GSXEX Knubbe
05-18-2007 07:57 AM
