Rebuilding the head
Old Feb 3, 2006 | 11:29 PM
jeffery0266's Avatar
Default Rebuilding the head
I am rebuilding my head.Oil is leaking into the plugs.I replaced the valve cover gasket and the plug seals.What I am planning on doing is replacing everything while I am in there.The car is a 99 eclipse with a 2.0 non-turbo.What I need to know is what would be the best parts to re-place all of the stock stuff.
Old Feb 3, 2006 | 11:38 PM
DSMTalonAWD51's Avatar
Default RE: Rebuilding the head
you dont need any special parts, just take your head to a machine shop and get a valve job etc, theyll clean it up for ya
Old Feb 4, 2006 | 12:32 AM
Wouldn't this be a good time to change the timing belt and everything in the head since the head will already be worked on?
Old Feb 4, 2006 | 04:36 AM
take it to a machine shop. if the valves are still good just get a valve job, they will tel you is they are resuable or not. if not replace em. there really isnt much else u need to do. u can do the timing belt while the head is off you might as well.
Old Feb 4, 2006 | 02:29 PM
Sanguinius's Avatar
And now for a bit longer of a list to do while you're doing the head job. replace the water pump, the timing belt, all accessory belts, and your timing belt tensioner pulley. That should be the basics of what should be done since you're already that far into the engine.
Old Feb 4, 2006 | 04:41 PM
93eclipsegsx's Avatar
yeah i learned the hard way on that. when i did my head, i changed the timing belt, accessory belts, water pump, but forgot to replace the trnsioner, and guess what happened. the tensioner went bad and caused it to jump time, costing me another 800 bucks!!!!
Old Feb 4, 2006 | 11:30 PM
ORIGINAL: 93eclipsegsx
same thing happend to TheEngineer(john) They did his timing belt but not the tensioner
Old Feb 5, 2006 | 02:02 PM
I apreciate all the response.I will do just that.Hopefully I will get everything fixed so that I can start on getting some horses in there.
buffboettcher
Dec 9, 2012 11:53 AM
VexerFrog
Apr 27, 2007 09:50 PM
DBIGGS
Feb 21, 2007 11:25 AM
95 Montero LS
Jun 13, 2006 03:14 PM
KillerEclipse
Apr 29, 2005 11:20 PM
